I don't know the way your installer originally had things setup.
The way I understand things work:
[*]Using the Firemans switch on the heater connected to the gas heater on the IntelliCenter:
- The heater is powered off when no heat and the heater controls are not accessible
- The IntelliCenter acts as the heater thermostat using its water temperature sensor
- The MasterTemp temperature sensor is only used during heating as a safety device for maximum temperature shutoff
- Heater status and error messages are displayed on the heater panel and not on the IntelliCenter
I can't say for sure that the heater is always powered on. I know the red light does not turn on until you call for heat from IntelliCenter. And when it's running, you can't do much with the heater control panel because it just says 'RS485 Control' on the display and you can't do much of anything except press a button to get the display to show current status. In a way, this doesn't match up to their guide for the heater bypass where they instruct you to go into the heater menu and enable BYPASS: https://www.pentair.com/content/dam...heater_auto_bypass_valve_replacement _kit.pdf[*]Using RS-486 temperature control between the heater and IntelliCenter
- The heater is always powered on and the heater controls are accessible even when the heater is idle
- The IntelliCenter tells the heater the desired setpoint
- The IntelliCenter water temperature sensor is not used during heating
- The heater operates independently of the IntelliCenter to run when it's temperature sensor says the water temperature is below the setpoint
- Heater status and error messages are sent to the IntelliCenter for display on the control panel and app
Calibrate the IntelliCenter temperature sensor to agree with the MasterTemp temperature and see if the pump speed and bypass valve operate at the correct times when the heater goes on and off.
I would have thought the heater would tell the IntelliCenter through RS-485 when the heater turns off and then the IntelliCenter knows it is ok to change the pump speed and close the bypass valve that the IntelliCenter controls.
You have no way to access that menu while it's connected as a MasterTemp via RS-485. Yet before the installer changed things on Friday, I was able to access that menu while the heater was running. I'm wondering what would happen if I left the RS-485 connection in place, but removed/added the heater in IntelliCenter as a generic gas heater? There has to be a way to get this bypass to work per their own instructions.
If it is relying on the IntelliCenter temperature sensor to know when to change the pump speed and valve position and the IntelliCenter water temperature sensor starts reading higher then the Mastertemp then will the IntelliCenter change the pump speed and valve position while the MasterTemp is running? That would not be good for the heater.
Wow I hadn't even thought of this but that's a very good point. If the water temp difference were swapped then I do wonder if IntelliCenter would have closed the bypass and changed the pump speed while the heater was still running. Now I'm concerned.
I think you need to discuss this behavior with Pentair Support. It seems Pentair has not thought through how the IntelliCenter and MasterTemp interact under RS-485 control. If the BYP_VLV on the heater worked properly the bypass valve would not be a problem but the pump speed change still would be.
You are at the bleeding edge of Pentair technology enabling their pool products. And Pentair is struggling to change to a technology company. With lots of technology Release 3 is when things start working. And this stuff is struggling with Release 2.
Thanks, I'll try to get a ticket opened with Pentair. The PB owner never did get back to me with a day/time to meet with their Pentair rep and I don't really expect him to at this point.
