Curious how everyone is running and protecting their control wiring.
I have an Intellicenter and VSF pumps. The control cabling is exposed and seams vulnerable.
Any recommendation?
When wires become entangled they are safety hazards, for both the equipment and the owner. Gardner Bender offers a variety of products for protection and neatness. As the needs of professional electricians
www.homedepot.com
I would also replace all those clear/white nylon ties with black ones that are UV resistant. The white ones will get brittle and crack from the UV in a year or two. The plastic flex tubing may also fail from sunlight exposure but its cheap and you can replace it when needed.
Where the cables are bound to the pipes you can paint both the pipe and cable with some latex paint to protect both from UV exposure.
It makes me cringe to see all that beautiful Pentair equipment out there in the Arizona sun. Consider a shed or shade structure to protect your equipment.
Those raised black cables between the pumps look like a tripping hazard to me. Either people will trip on them or snag them with a foot and damage them over time. I would wrap that area in tubing or a slit pipe and run it on the ground between the pumps.
I zip tied my actuator valve cables, flow switch wire, temp sensor wire, my salt cell cable and pump control wires to the plumbing like yours is, but I tried to put them under them pipes shielded from the sun. I ran mine along the plumbing to the closest point to my Omnilogic panel then encased them in the wire loom over to the actual panel. I still felt bad about all my equipment being out in the weather and built a roof over it.
I agree with tho wiring just awaiting to be tripped on. I will be rerunning all of them once the PB is finished with startup.
I will also be adding some sort of shade structure to cover the equipment.
I am not very happy with any of the electrical organization and will be cleaning up all the wires even inside the IC. Thanks for the input and ideas.
