- Jun 1, 2018
- 14,259
- Vinyl
- Hayward Aqua Rite (T-15)
The average pool uses 2-4 ppm of fc daily - after your initial dose to reach target fc range for your cya of 90 (10-12ppm fc)Ok. Thanks everyone for the dose of reality. The pool looks great but I will plan on draining water out a little at a time and get the cya back down. funny thing is, I had it down and that was the only time I saw some hints of green. Anyway, to hit my pool at FC 7 would take at least two gallons of bleach a day which is about 6.50 a gallon at wallmart now. Any other places to buy and better percentages that you suggest.
You will just be maintaining that daily by replenishing what is lost- not going from 2 to 10ppm daily. That would be around a gallon of 10% liquid chlorine daily give or take - u have a large pool.
If u are losing more than 4-5 ppm/ daily you should do an Overnight Chlorine Loss Test to rule out an algae problem. You should probably do an oclt anyway since u have been below minimum for your cya for some time. If algae is confirmed you will need to do the SLAM Process to eradicate it- this isn’t practical w/ a cya of 90 so a decent water exchange will need to occur sooner rather than later.
Here’s some info on that
Draining - Further Reading
www.google.com
If daily dosing is an issue, you may want to look into a saltwater chlorine generator to produce chlorine for u & feed your pool daily. You would need a unit rated for 60k gallons, as that is the largest anyone makes.
