According to Pool School, my Chlorine should be at 6. It's been between 7 and 9 with my SWG only running at between 5 and 25% and the pump running about 8 hours per day. Some days I've cut it all the way down to 0%, but it appears it still registers as 5% on the control board. We received 2.5" of rain last week, but the temp can vary between 35 and 80 in the span of a few days. From what I can tell, the slightly higher chlorine is not a problem, but my question is, at what level would it become a problem. No doubt as the days get longer and hotter, this will not be an issue. I cut the SWG all the down again this morning because these readings indicate that even after a few warmer days and all that rain, the chlorine is holding strong. I guess that's a good problem to have, just curious as to whether or not my safety buffer could become an issue. Thanks in advance!
FC: 8.8
CC: 0.0
pH: 7.8
TA: 80
CH: 410
CYA: 80
SALT: 3400
BORATES: 50
TEMPERATURE: 65°
CSI: -0.22
FC: 8.8
CC: 0.0
pH: 7.8
TA: 80
CH: 410
CYA: 80
SALT: 3400
BORATES: 50
TEMPERATURE: 65°
CSI: -0.22
