- Jul 14, 2017
- 743
- Plaster
- Hayward Aqua Rite (T-15)
Hi all -
I had a light flickering in my hundred year old house. I figured it was just a bad switch but replacing that didn’t fix the problem. a little more digging...turns out there is still knob and tube in my house!!!! YAY!!!
All other fixtures on this circuit are working no problem and test at 120 volts. The one light which wasn’t working so well tested at only 60 volts at the switch. No idea what is behind the voltage drop - I assume a bad connection somewhere along the line.
As of now I’ve just cut the old switch and fixture out and capped the wires. I think my best solution (that doesn’t involve major renovation) is to rewire this one fixture from another nearby circuit (modern romex) and just leave the K&T capped and in place. This would leave hot K&T in my walls but without current running through the faulty part. I think this is a reasonably safe solution.
I am planning on calling an electrician about this. But there’s a lot of smart people on this forum so I thought I would put it out there.
