- Jun 23, 2019
- 354
- Plaster
- Pentair Intellichlor IC-40
Throwing this out to see if it is possible with an EasyTouch 8...
With the spillway running and in Pool mode, is it possible for the spillway function to be turned off automatically when the call for the pool heater to be on, then when the pool heater is off the spillway turns back on. Both Valve A&B are already used for Deck Jets and Bubblers. The EasyTouch is Pool/Spa, I only have a pool, no spa, but I want to use the spillway function to control the 3-way valve that operates the heater bypass.
