Hello,
I have an easytouch pl4 that has a pool circuit that is scheduled to run at 2000 rpm from 6 am -10 pm. There is also a higher speed circuit that runs 2400 rpm from 6-8 am and 8-10 pm. As well as a waterfall circuit that we turn on and off manually that runs at 3000 rpm.
For some reason when the evening schedule of 2400 rpm kicks on it turns off the pool circuit. Not usually an issue except it also turns off my heatpump.
Right now we have the pool schedule running 24/7 (still with the overlapping higher speed schedules) to maintain water temperature but I have to remember to turn on the pool circuit after 8pm or my heatpump doesn’t run.
I thought it was the egg timer but I’ve switched that to don’t stop. Do I need to adjust the egg timer for the high speed to don’t stop as well (even though it runs fine).
I can’t figure out why my pool circuit gets kicked off at that later time. Turning the waterfall off and on manually doesn’t affect the pool circuit.
I’ll attach a pic but if the pool light isn’t green on my pump schedule the heatpump doesn’t run. And that is what is being turned off at the higher speed in the evening only.
Thanks for any help.
Laura
Laura
