OK, so I *think* I have my solar cooling enabled.
Max temp set higher than Set temp in Heat menu.
But my questions are:
- Will the set point trigger also start up the pump?
- How do I get the pump to kick on if/when the array is cool enough, but not turn on if it is not
- Can I just sent 4 hours of cooling late at night [my preference].
- If the pump needs to be running, is there a way I can enable/disable a late night schedule [say 2-6 AM, but only when the "Cool" button is pushed?]
- And/Or, if it is not cool enough to cool, can I avoid running the pump?
