- May 23, 2017
- 24
- Vinyl
- Pentair iChlor 30
Hello, I found this forum a little while ago and it would be great if i could get some help regarding my easy touch system.
Our pool was installed 2 years ago with the Easy Touch system. When it was initially installed the PB did not setup any of the actual control system. The easy touch system was just used as a load center for all of our equipment. Up until this point for the past 2 years we have just used the load center to control the equipment and have turned the various equipment on and off by using the breakers. This year i decided i want to take advantage of the system we have.
I have some basic electrical knowledge and I am okay at reading diagrams so I think I can do all the wiring myself. After doing a little bit of reading I discovered the Pentair manuals are not the best. So I read some posts on here and looked at some youtube videos and this morning decided I was ready to give it a shot.
When I opened my panel up today I discovered the PB had not done any wiring for the control system other then the control system transformer. Not even the relays were plugged in.
I decided I would try turning on the system by turning on the very bottom breaker of our load center which we have never payed attention to. After turning it on nothing happened. The LED displayed did not light up and no lights turned on so i went into trouble shooting mode. I figured it was a problem with the transformer and after taking a look at the diagram on the panel door i think the PB wired it wrong!!
I forgot to take a picture at this step but what he had done was put the Black and Yellow 120V load wires into the circuit breaker AND then put the purple wire on the neutral. So basically all three wires were attached! in both the 120v and 240v diagram never are all three attached. 120 is the black and violet wire and 240 is the black and yellow. I assumed this was the problem. Then came the decision if i should wire for 120 or 240. My Pump (Pentair superflo 1hp) is 230v and my heater (Pentair mastertemp 200) is able to run on 120 or 240. There is two breakers for it so the PB must have set it on 240v. Realizing this i determined i needed to wire for 240v. So I removed the violet wire, capped it, went to turn the system back on and nothing.. no power.
At this point i dont know what to do, i dont believe any of the lov volatge breakers are tripped, all my other equipment works fine and I think i wired it correctly. If anyone could help me it is very much appreciated. Pictures are attached.
Here is how i wired it for 240v (very bottom breaker)
LV breakers
Load center wiring
Labeled breakers (Top three dont relate to equipment as they are Cabana plugs "P", Lights "L", and Fridge "F"
