- Jun 22, 2014
- 52,024
- Fiberglass
- CircuPool RJ-45 Plus
When you get a chance, could you validate your CYA and FC please? I think the last CYA was from Monday at 40?
I really don't get it. I've never even had that when the pool was green in the past before.Yikes! That's some green stuff. Wow.
I just rechecked the cya because I was afraid maybe I was wrong last time. I did it 3x with the same solution dot goes away at 38-40. Fc just checked 12.5 bumped it back to 16.When you get a chance, could you validate your CYA and FC please? I think the last CYA was from Monday at 40?
Good catch!I did it 3x with the same solution dot goes away at 38-40. Fc just checked 12.5 bumped it back to 16.
It can play tricks on your for sure.The dot on the test messes with me since I wear glasses but I am sure I still saw the dot above 40.
Going to MA level is the absolute last step applied after passing the normal SLAM criteria. When someone increases the FC to MA level, it's only for 24 hrs. But again, you must complete the normal SLAM criteria first.When would I be able to bump the fc up to that level if every morning the algae is back on the floor if it is mustard algae and then I wont pass the clear criteria???
You still got algae with that crazy backwash water color. Dont worry about mustard algae right now, you gotta first get rid of the regular algae thats there.What if this stuff that appears at the bottom of the pool every morning doesn't go away? I washed the heck out of solar cover today so I am hoping that helps.
Thank you I am gonna keep on my normal SLAM. Maybe I'm chlorine deliriousGoing to MA level is the absolute last step applied after passing the normal SLAM criteria. When someone increases the FC to MA level, it's only for 24 hrs. But again, you must complete the normal SLAM criteria first.
It was a good 2 min backwash and 1 minute rinse. I am thinking maybe I will backwash again tomorrow? Hope it's not that bad again.You still got algae with that crazy backwash water color. Dont worry about mustard algae right now, you gotta first get rid of the regular algae thats there.![]()
Almost guaranteed its needed again.It was a good 2 min backwash and 1 minute rinse. I am thinking maybe I will backwash again tomorrow? Hope it's not that bad again.
Make sure you are brushing every time you see it so that it breaks the biofilm, your in great handsWhat if this stuff that appears at the bottom of the pool every morning doesn't go away? I washed the heck out of solar cover today so I am hoping that helps.
We have been brushing 2-3x a day. I have been using my dolphin too... is it better to brush it or vaccuum it up in the morning? I considered vaccuming to waste tomorrow but I'll need extra water put in.Make sure you are brushing every time you see it so that it breaks the biofilm, your in great hands
Will post a pic of what color it is tomorrow lolAlmost guaranteed its needed again.
Certainly possible.Is that dead algae?
Good. I like dead algae. I put a skimmer sock on hopefully that will help catch it.Certainly possible.
