Hard to know why they dropped really. But since your CH and TA seem to be in fairly good shape, continue to monitor the pH to ensure it doesn't drop any lower ~ especially for the health of your heater (not sure if you have copper in there). If you have a water feature, crank it up as well which should increase pH a bit. Remember that as our water temps drop, pH tends to increase slightly. If you can get pH around 7.5 that would be ideal.
As for the FC, it's definitely too low. Even in the cooler months we expend FC, just slower. It looks like you manually feed your pool chlorine (non-SWG), so depending upon your current CYA level, make sure to increase FC as noted on the
Pool School - Chlorine / CYA Chart page. Hope that helps.
