- Jun 24, 2021
- 16,042
- Vinyl
- CircuPool RJ-60 Plus
Yeah, it can happen. Do you have baskets in your skimmer(s)? Do you have a main drain? Sometimes they can get through. That cover is the cover to the pump basket. Think of it as a "pre-filter" to keep big stuff out of the pump and filter. Are there a lot of leaves or just one or two? To clean it, I would turn off the pump. Close the valve on the tall pipes in the back. The handle should face away from you or 180 degrees from the way it is in your pictures (this will keep the water from coming out of your pool through the pump basket when you take the top off the pump). You unscrew the clear top and empty the basket. Put it back in, top back on, turn the valve back so handle is pointing toward the pump. Turn on the pump.Nope this one connected to pump.
Thanks @Newdude. Just turn the output to 0%. Good to go!Also for swg there is no off switch, not even a trip in the electricity box, the swg itself has a sanatizer output that can be reduced
