- Jun 24, 2021
- 16,042
- Vinyl
- CircuPool RJ-60 Plus
Likely ok, at 28 and 25% rise being 31/32, your are likely ok.k I'm caught up with some work, but I'll try to reach the SLAM parameter today. And do OCLT. I'll run a few cycles of nautilus as well.
Do I need to clean the filter before leaving, or can I leave it for the next 2 weeks with the SWCG/filter pump running 7-8 hrs daily.
On the pump/SWCG side, the challenge is that we don’t know how much FC your pool consumes daily. Your cell produces 5.4 FC at 100% running 24 hours. 8 hours would give you 1.8. If your pool loses > 1.8, you will come back to algae. We’ll need to see if we can figure this out before you leave!
Skimmers work great. You will want to lower your water to the center of the skimmer…Lastly I know my skimmer is not working properly right now because of the waterline, but what do you guys usually do for skimming - manual/robot or do skimmers do a good job if the level is correct?
