- May 25, 2020
- 83
- Plaster
- Pentair Intellichlor IC-40
I am having to drain my pool (finishing today) due to high CH/salt and will start refilling immediately when complete. I remember when I initially started up my pool, there were certain aspects and order that the chemicals were added to ensure proper balancing, and there was one in particular that you had to keep the SWG off while adding (I think it was CYA, but it wasn't a problem before because I didn't start my SWG until 30 days after anyway, though I do recall reading that it should be off if adding whatever it was). I tried to re-read the ABCs but it does not give this info and I can't remember where I found the proper order/procedure and what should remain off when balancing your water initially. Is there a link to this guide that I can't find?
And if not, what should be the order of adding chemicals to get my water back in balance properly?
