I have a Doheny Dolphin Discovery; I believe it's equivalent to the Maytronics S200. This will be its 6th summer. It worked fine last summer and was stored in my garage over the winter. I built my own power supply for it that has worked flawlessly for a few years and is outputting the required DC voltage, so my issue is not related to the power supply.
Basically, when I turn it on, the unit starts like normal - the blue light starts blinking and the unit moves back/forth and then starts its cleaning cycle. However, VERY shortly into its cleaning cycle, it stops completely and the blue light goes out. Initially, it would stop after about 30 seconds, but each time I restarted it, it would run progressively longer and has now maxed out at about 2 minutes.
During the time it does run, it seems to be working. It's definitely vacuuming and the tracks and sweeper spin. I haven't been able to get it to climb a wall and move sideways yet, so I'm not sure if the deflector is moving, but it does move easily enough by hand, so I know it's not jammed. I also confirmed that the impeller turns easily enough by hand, and again, it is definitely vacuuming.
Anyone have any idea what would cause it to shut off so quickly? Are there any sensors within the unit itself that shut it down if it:
- Overheats
- Jams
- Isn't generating enough suction
- Overload (see power supply note below)
- Over-/under-voltage (see power supply note below; I don't think this is really the issue, but could be a bad sensor)
- Has some sort of "navigation" or position sensing error
- Etc., etc.
Lastly, regarding the power supply, I have it outputting 29.6 volts at the power supply (multimeter verified), which is the same setting I've used since I built the power supply a few years ago. It's a 480 W power supply, and the wi-fi switch I have connected to it, which also monitors watts used, hasn't gone above ~140 W, although the update frequency is only about 15 Hz, so it theoretically could spike an overload that I wouldn't be able to detect. The total DC wire length is longer than just the cord to the unit because I have the power supply remote mounted and run a poolside connection under my patio. Again, the 29.6 volts has worked fine with this setup for a few years, but thinking maybe I had some wire degradation over the winter, I bumped the voltage to 32 volts and got the exact same result - starts then stops.
Also, what's the typical lifespan of these things? Again, if I can get it going, this will be my unit's 6th season. It's in the pool (SWG, vinyl) 24/7 during the season and I set it up to run 2 hours daily. At the end of the season, I clean it thoroughly and store it dry in my garage. I'm in NJ, so our season is about 5 months long, which equates to about 280 hours per season.
Thanks!
- Overheats
- Jams
- Etc., etc.
Thanks!
