Dolphin Nautilus CC Plus Belt Came off - New!
jknapp86
11
NJ
Has anyone had an issue with one of the belts coming off the track on a newer CC Plus? Just bought this Summer found it very strange one of the belts seemed to have dislodged and popped off the bearing of the front wheel. Found it strange as the unit was just purchased this summer. Think maybe it was just a fluke and caught on the stairs or something? TY!
Buggsw
927
Arizona
I just had this happen to mine. Now it isn't running correctly. It moves extra slowly and just isn't acting like it's normal cycle. I unplugged it and plugged it back in and now it seems like it is just going through it's test for a couple minutes then turns off and the light turns red on the power button. Time to see how good they are on the warranty. I just bought it this past April.
Buggsw
927
Arizona
As I posted earlier, I also had this happen to mine just yesterday/maybe the day before. I just know it didn't work this morning and I pulled it out of the pool and saw the belt was off the track. Thought I was going to have to travel 40 miles one way to get it fixed. Then I thought, let me see if I can see if something else is wrong and I did! I could see something lodged in the gears.
I found a video on how to open it up and sure enough. Apparently my cleaner got in a fight with a kids beach/kick ball. I saw a torn up one over by the corner of my pool steps and thought some neighbor kid probably tossed it over and an animal got to it or something as it had a large piece missing. Yep, that piece was what was folded up and scrunched into the gears. Put it back together and it's working like a charm again. Thank goodness.
Solrayz
20
Las Vegas
This would happen on my CC Plus on occasion and is a total mystery to me. I replaced the belts and was good for about a month, then it did it again. When it does this, it seems to stretch the belt ever so slightly, so it may reoccur with more frequency. Every time it does this, it damages the styrofoam on the side. I had to replace that once as well. I was never able to figure out why this happens and never actually witnessed it happening either. And besides the black marks it leaves all over my plaster pool, its a decent robot despite this.
BTW, I just sent mine in for warranty repair, for the same reason. Track came off for the last time, and never acted right afterwards. Motor malfunction. Bought it back in June 2019, so clearly longevity with these things is questionable. I purchased a Doheny's Discovery in the meantime, and will have the Nautilus as a backup.
Aspfam
56
Grand Rapids, Michigan
Purchased mine back in May 2020. Worked fine for 6 weeks or so but then the tracks started coming off and it wouldn't move. I tried getting it back on without removing any parts. Was not successful. Finally found a video on how to take them apart and pulled the cover and side pieces off. One of the foam blocks was damaged pretty bad. The other side not as much but still had damage. Put them back on and it ran for less than an hour before the tracks came off again. Sending it back to Maytronics tomorrow for warranty repair. Not at all happy. Given the cost of the unit and the fact that it's only 4 months old I expected more. Customer service said they have received "some" calls regarding the same issue recently.
morzh
253
Jackson, NJ
I have it since the spring.
It came off within a week.
I wrote a scathing review and this got the Maytronix attention, they gave me a vase # and said I could send it in.
This would leave me without a cleaner. So I keep using it.
Today something worse took place: the track not just came off, but then after having been put back refused to rotate making snapping sounds.
Upon inspection, it also got off the channel inside. There is something it goes under, a smooth tensioner ot an idler....so I had to disassemble the thing, readjust the track, then put it back together, then put the track over rollers outside. Then it worked.
Maytronics Dolphin does superb job cleaning. Way, many levels above what the Diamond can.
But the workmanship is shoddy.
