Dolphin M400 climbing issues.
elwayfan446
5
Conway, AR
Hi! I recently replaced the tracks and climbing rings in my Dolphin M400 as Patrick described in this old thread. It moves better but still won’t climb my walls. We just had a new pool liner installed too so traction shouldn’t be a problem. Any idea if I needed to refurb any more parts or what else might be causing my cleaner not to climb the walls? It is driving me crazy!
Old thread:Dolphin Premier M5 - 4th Season Refurb
setsailsoon
3,839
Stuart/FL
CircuPool RJ-30 Plus
46,
Just a guess but how long since you cleaned or changed your filters? I was amazed at how much filter plugging affects the ability of the pump to produce a vacuum even when my robot was brand new. Since you've replaced the most likely wear parts this may be your problem.
Chris
BowserB
393
Katy, Texas
Kimkats, the M400-500 are a different series and very different design from the "So this just happened..." post. I run my M500 (same as M400 but with mostly useless Bluetooth app support). I run it once a week, sometimes twice, but I always take it out after a 3.5 hour run time. I then clean out the filters and rinse off both all the cleaner and cable, making special effort to flush out all the places that might retain chlorine. I especially rinse out the path of the vacuum propeller. Watching it at work, it seems the keys to wall and waterline cleaning are the vacuum strength and the floats, which I keep at a maximum angle to facilitate moving along the waterline. After rinsing, I let the cleaner dry on its caddy, then cover it to protect from the sun. This cleaner with its third brush placed amidships, does an extraordinary job of scrubbing the pool bottom and sides (especially compared to the pressure side cleaner the PB provided!) When asked, I usually recommend the M400, as I have a program set (3.5 hours, bottom and sides) and have neither the desire nor the need to manually drive the cleaner around the pool.
All that said, after two seasons, it does seem to not climb quite as high on the waterline as it did the first time I put it into the pool. My pool has a kind of pebble finish, and I suspect that increases wear on both the brushes and tracks, although that wear is not obvious to look at. I wonder if a soap and water wash of those moving parts would be beneficial. Could the tracks plus front and rear brushes have accumulated oil that is not obvious to the touch or eye? I use the pleated filters pretty much all the time, as they should have greater filter area than the others, but I'm not certain about water flow resistance. Elway, keep us posted on your efforts and results, please.
Reactions: scomea
Katodude
1,270
West Palm Beach/Florida
Hayward Aqua Rite (T-15)
My M500 climbs the walls better with the mesh filters than the pleated filters.
However, a small modification can help. Put a pool noodle on the bars that support the floats. Gives the unit more buoyancy.
Reactions: setsailsoon
