Doing the Slam method need some advice please
MommaBear14
2
Chattanooga, TN
I'll start with I'm new to pool owning. I have a vari speed Hayward PowerFlo Matrix Pump with a Hayward Sand filter that I have glass media in instead of sand due to all my research saying glass was better. We put the pull up last fall and filled it. I covered it with just a leave catcher over the fall (have learned my lesson) When I opened it this spring it of course was green and I could NOT get my levels correct. At first I will admit I was using chemicals like Floc and Algaecide treatment BEFORE I found this lovely site and community. I learned I needed to do the slam method, but before starting I needed to get my CYA up which I did. I'm on day 3 of the slam method, using 7.5% bleach (I am using the Pool Math app to help which I also learned here) It has improved slightly and I know that sand filters apparently take the longest to do the slam method. This is a picture of my FC test, due to it being ALOT darker than what it goes to I have just been putting 10ppm in the FC calculation and my current CYA is 60 so it has been telling me to add 2.8 jugs of 7.5% Bleach. I have been doing this 3 times a day. As I have stated it has improved slightly. I would say I went from maybe only being able to see 1ft under the water to now 2ft. My question is 1. Due to the color being off the charts and my basically guessing am I using the right amount of bleach? 2. Just keep doing what I am doing? 3. Can I also hook up a different pump (like a sump pump) to filter through a bucket that has cotton balls or something in it with holes back into the pool to help? I add this question as when I started the slam method I also learned about filter socks in the slimmer and have had to change this like 5-6 times daily due to how disgustingly gross they are getting. Thank you in advance! IMG_0194.JPG
Welcome to TFP! :wave: Glad you found us. Your enthusiasm is great, but you're a bit ahead of yourself without a proper test kit. You really must get yourself either a TF-100, TF-Pro-Series, or Taylor K-2006C test kit. That way you can be sure of the exact FC level to match your current CYA. That is a priority. You can't so the SLAM Process with those basic OTO block viewers. I'll place some links below to help.
Until you get one of those kits (I recommend the TF-Series), just add one gallon of chlorine per day. Don't try to do too much right now or you could waste chlorine and $$. :)
Here you go!
The kit I have currently is the HTH 6-way test kit. I looks very similar. But I'm guessing it's different some how? Sorry I'm learning and would love to know the exact differences if you know them?
HTH 6-way test kit.
You are off to a great start!! Well done!
That is a good kit as it has almost all of the tests you need. The biggest problem is the number of tests you can do with this "baby kit". You will only get a couple/few tests out of each one. The test kits we recommend are more bang for your buck in that they have a LOT more of the regents to do the tests.
Reactions: Texas Splash
