We just opened up our pool and it is extremely green and full of leaves and sticks that somehow blew under our mesh cover. Our pool pro blindly removed some leaves and sticks but I imagine that he didn’t get all of them since he cannot see the bottom. I’ve SLAMMED a pool many times before but I never have done it when it was this green and full of leaves and sticks before. I’ve also never SLAMMED a pool with Cal-Hypo shock but it looks like I have no choice because Walmart, Lowe’s, Home Depot and all of the farm and hardware stores in my small town are out of liquid chlorine. Bleach without fragrances and additives is also impossible to find due to COVID-19. Before I start the SLAM, I have a few questions:
1. How long do I need to run the pump before I can test the PH and CYA so I can determine my shock level and start the SLAM?
2. Thunderstorms with high winds are expected tonight and tomorrow so I’m going to have to turn the pump off tonight and keep it off until tomorrow afternoon since my pool is surrounded by trees. Should I go ahead and shock the pool with some Cal-Hypo today so the pool doesn’t get any greener than it already is before I turn the pump off tonight, or would this be a waste of pool chemicals?
3. Since I have a fiberglass pool with a low calcium level (100), can I broadcast the cal-hypo shock and brush afterwards, or do I need to dissolve it in a bucket and pour it around the pool? I have a bad back so dealing with a heavy bucket full of water is difficult for me.
4. Am I going to be able to clear up this pool enough to see the bottom if our pool pro wasn’t able to get all of the leaves out? Once I can see the bottom, can I vacuum up the leaves to waste since these are tiny birch tree leaves that are in there, or do I need to manually remove them with a net?
5. If CYA is 0 like I anticipate, can I start off the SLAM with Dichlor and then switch to Cal-Hypo when CYA reaches 30 instead of putting some CYA in a sock in the skimmer when I start the SLAM?
