Can I change to Cal-Hypo from liquid during the middle of slam. Should I let the liquid get used up or near zero or can I just start adding cal-Hypo on top of the 16PPM liquid currently in the pool
Thanks for the reply. I did get 20gal of liquid at Lowe's for $7.78 gal. (9.98 Gal at Home Depot) Found Cal Hypo at Walmart for $39 that may get me thru the slam if I need more. Glad to know I can use it in the pool with the liquid already in the pool. I was reading the safety tab on the Cal Hypo and was concerned. Thank you for the quick reply. I may get to swim by June!!!!!Cal-Hypo is not preferred in the long run, but if you are in a pinch and must use some, you can add it to the water at any time to maintain your SLAM level. The danger is to NEVER add liquid chlorine and Cal-Hypo together in a container or the exact same spot at the same time.
Thank you, I just didn't want to blow up my pool, although, this slam does make me want to at times along with all the other problems opening this year. I think I may be the poster boy for having problems opening each year. I'm sure MOST of them are self inflicted. Thanks to all for the repliesAll forms of Chlorine work to their ability. If you can spare the rise in the binding agent (CYA, CH, or water) you're welcome to use the appropriate one.
Except for pucks in this case because they're slow release.
And none of them play well together as said above so use proper caution.
*username checks out.I'm sure MOST of them are self inflicted.
x2 for Walmart in Ga. They have the best deal around.In stock, Walmart, 1735 S Highway 27, Carrollton, GA 30117, Isle F8. $5.47 a gallon.
Might also try a pool store. Mine has 12.5% for the same price as a few years ago. Maybe that means it was overpriced to begin with…Thank you, I just didn't want to blow up my pool, although, this slam does make me want to at times along with all the other problems opening this year. I think I may be the poster boy for having problems opening each year. I'm sure MOST of them are self inflicted. Thanks to all for the replies
I was there on Tuesday. I pulled it up on-line and saw the price. It is next door to Lowes. Got there to find the shelves empty of liquid. I guess many Carrollton folks love the liquid. I will keep an eye out. Started out buying the walmart brand when I joined TFP in 2017 and it was $1.88 gal. then.In stock, Walmart, 1735 S Highway 27, Carrollton, GA 30117, Isle F8. $5.47 a gallon.
