Doheny's Discovery, S200, Active20, Triton owners club
DjEclipse
91
Ontario
Now he's noticing how much less lawn he has to mow. :)
Get one of these and he will never have to mow the lawn again!
Tenab
162
NE Texas
I'm happy to have found this thread and the info
  • Pentair Prowler 920 = Dolphin Active 20 = Dolphin S200 = Dolphin Cayman = Dolphin Nautilus (2017 and Later) = Dolphin Proteus DX3 = Doheny's Saturn
I was not happy about having the 920, but this gives me hope. One more week until it gets tested out... or should I test is some way before I put it in.
Mine is an 820 🤦 I'm back to being disappointed.
bmoreswim
Platinum Supporter
5,446
Central MD
It’s an older style Dolphin. Honestly, many folks have reported great life from older Dolphins. Though they may lack the easier basket or fancier navigation, blah, blah, blah. I suspect you will get good service and a good clean pool for a long time with it.
Reactions: Tenab
Viperscorpio
48
Arizona
So, right now I have a poorly performing suction cleaner that needs my vsp to run fairly high (2600rpm). If I switched to a robot, like the active20, would I really be able to drop my rpms to like 700 just for circulation? How do I know if I'm getting good enough skim?
Thanks!
swing4terps
Active member
May 21, 2016
38
Harford County, MD
Another Active 20 dud here. Ran <10 times and now it will run for 20 mins or so then just stop. Conveniently decided to die before and after our biggest swim load of the season. Will be contacting the dealer or Maytronics tomorrow morning.
mknauss
22,731
Laughlin, NV
Thanks!
A robot has its own pump and filter.
Your VS pump should not be run below about 1000 rpm. It gets really inefficient at that level. For skimming, start at 1200 rpm and see how it does. If not good enough, raise it by 100 rpm each time to see what works. Your electricity used at 1200 rpm vs 2600 rpm will be at least a drop of 75%.
Arizonarob
2,947
Chandler Arizona
This is from another member, give it a try.
Wasn’t sure about linking other websites, but the copied steps are below. Note on step 5, mine ran for several minutes, not the 30-45 seconds.
1) Unplug everything. Unplug the power supply from the outlet and the Dolphin from the power supply.
2) Let the whole thing sit a couple of minutes (we want to allow any capacitors to discharge).
3) Be sure the Dolphin is out of the water and sitting upside-down on a level surface (Tracks pointing skyward).
4) Reconnect the Dolphin to the power supply and the power supply to the outlet.
5) With the Dolphin still out of the water, perform a self-test. Simply turn on the Dolphin. Within about 15 seconds it should begin to move. The tracks will spin in both directions with and without the impeller motor running at the same time. It is not unusual for the tracks to rotate at different speeds during this test. The test will last for 30 - 45 seconds or so. If it goes on indefinitely, turn it off and contact us for further direction.
6) Assuming the unit has now worked to this point, you should be able to put it back in the water and it will return to normal operation from this point on.
RC121
63
Scottsdale, AZ
I had finally decided to spend the money and get a dolphin but now it seems prudent to hold off until these issues resolve or if a few others are able to troubleshoot it like above
TigerFanatic1
Active member
Jun 1, 2019
25
Louisiana
For clarity, mine only gave me issues once and that was when I tried to start a cycle immediately after it completed the first one. I contacted the manufacturer via email, but their reply was only a confirmation of receiving the complaint. To say the least, I’m not impressed with it and their lack of communication leads me to believe they are fully aware of the issue, but do not have a solution. If it happens again, I will make a better attempt to contacting them.
SilverJK
106
Is it normal for the Dolphin Active 20 to completely miss (undisturbed floor areas) during a cleaning cycle? My new cleaner has glaring spots it has missed on mutiple occasions; even the same corner in my deep end several different times.
mknauss
22,731
Laughlin, NV
Check to make sure the cord is not restricting it from getting to all areas of the pool.
My pool is small compared to yours -- and the robot cleans it perfectly.
SilverJK
106
I will say that I've have provided plenty of cord unrestricted and the other locations it missed were in the center. Could I have not gotten the correct robot or something is wrong in its calculations? I purchased it on the advice of Marina when I described my pool and size to them.
Azred
2
Phoenix
If that quote is from another website, I think some of their brand comparison data is erroneous.
swing4terps
Active member
May 21, 2016
38
Harford County, MD
Just an update: Didn't bother trying to troubleshoot. Called Marina and had a return authorization the same day. Boxed up the robot that night and dropped it off the next morning. Maytronics had one shipped the same day and all-in-all I was <4 days without the robot. Have only used the new once and everything ran fine. Only thing I will say is they seem to have an issue restarting after a cycle is completed. If I want to run it for another hour I found that I have to shut the controller down for a minute and then restart and select before the robot will begin its cycle. Perhaps that's how it's designed, perhaps it's not. But it's not enough of an annoyance for me to look into it.
Despite my issues, would absolutely still recommend one of these. When working properly they are effective well worth the cost IMO. Not having to wake up every weekend and spend a couple hours manually vacuuming the pool has been great. Drop it in twice a week, cleanup takes <5 minutes, and my pool is cleaner than it's ever been. Just make sure to keep the box it's shipped in. ;)
Reactions: MyAZPool
