Hello TFPers. We used the spa last night. We had a solar cover to help heat the spa faster. Total time from start of heating was about 3hours until we finished bathing. I noticed the spa was a little murky afterward. It was late so I didn’t test the chemistry. This morning I tested the spa and not the pool since the pump hadn’t come on yet. Result was almost zero chlorine and my PH was higher than my usual 7.8 .
I keep my pool/spa typically around 4ppm and 7.8ph for my 30cya. I know the hot spa water will burn off chlorine and also ph will rise due to the water bubbles from the jets. To prevent the chlorine going to near zero again and water get murky, shall I add extra chlorine before using the spa every time?
