Does CYA "degrade" or does the test just kind of suck?
I did an AA treatment and big water removal at the start of the season. I assumed a CYA of 0 (likely it was a bit higher due not removing ALL water) and added 10 cups of CYA via sock in front of return.
A while later, real life hit me hard and I let things go. Pool was a bit green and I was going on vacation for ~1 week, so I tossed in a bunch of bleach. Came back to a pretty green pool. Figured I'd test the CYA again to make sure my chlorine was near peak effectiveness (not getting chewed up by the sun before whacking all those baddies).
CYA results are poop - filled up the whole vial and can STILL see the dot. What? I put in 10 cups early this season!! Why does this 1 test suck so bad? LOL.
I'll add more now, probably8 4 cups when I should do 10, because I don't believe those results but do think it's a bit low due to the green I've been battling.
Thoughts?
Thank you for your help.
Thoughts?
