My hot tub sits elevated on the corner of my pool. When I run the hot tub I turn off my pool pump and shut off the spa return and turn on my spa pump. That way I cycle just the water in the spa and it does not spill over into the pool.
at least once a week I will turn on the pool pump and then cycle the water into the pool.
If I do this do I need any different kind of chemical levels while the water is in the spa?
I currently use my winter rules and have try to keep FC at 3ppm and ph at 7.8 or just below but above 7.5
