Today I finally got around to addressing the spa spill over. The surface of the flagstone over which water poured into the pool has always bugged me in that it created an uneven, erratic waterfall which would turn into a strong dribble when it neared time for replacing a dirty DE filter. Well, the grinding down of the flagstone surface produced the desired effect..I now have a beautifully symmetric cascading waterfall I never had before. Unfortunately, it created an unavoidable deposit of extremely fine ground flagstone into the pool making it very cloudy. I’ve run the DE filter - newly replaced DE BTW - for about 9 hours now and it’s still very cloudy.
I plan to run the filter all night..but am wondering if the DE will be able to filter out such fine particles? I’ve read posts varying in the micron size DE will effectively filter out, but am thinking the powdery like flagstone waste from this project is too fine to be addressed by the filter.
I heard clarifiers act to bind together fine materials so the filter can catch them..but others claim the DE will get clogged up. It’s no big deal if I need to change out the DE, but still left wondering if (i) filtering alone will do the job, or (ii) if the clarifier will serve a useful purpose as just noted. I’ll check out the water tomorrow but if it’s still cloudy, I’ll probably think it’s had enough turn overs after 24 hours straight (13 gallon pool with filter set at a fairly high RPM) and grow concerned that further running of the pump will have turned to be a costly waste (scary high KWPH cost here in San Diego). Being a tad bit over 400 ppm already in calcium content further concerns me, so wondering if this alone necessitates a partial drain (assuming / if that fine sandstone has moved that calcium level even higher)?
Thoughts anyone?
Thoughts anyone?
