- Jun 7, 2019
- 56
- Plaster
- CircuPool RJ-30 Plus
Perhaps a dumb question, but can't hurt to ask.
New (to us) house, built in 1992. Water bubbles coming out the returns. Existing valves are Jandy, I believe non-positive, They were dry as a bone so I replaced the o-rings and broken grease cups. Also cleaned and lubed the pump and filter o-rings. That stopped the air bubbles for a while, now they're back.
We were away for a few days, and the pump lost its prime. (surprisingly, it seems undamaged). There are no obvious cracks in the pipes or valve bodies. Clearly there is an air leak somewhere, so I'm going to re-plumb the whole system with new valves and a new larger cartridge filter. Pump is a 1.5hp Intelliflow VS
My question is, should I put a check valve in front of the pump's intake? I realize that in a properly functioning system with no air leaks the pump should not lose its prime and a check valve should be unnecessary. But is there any downside? We are away a lot in the summer, and if something goes wrong and there's no water flow then the SWG can't do its job and I don't want to come back to a green pool. It's just a pool, no spa and no heater (yet).
Bonus question, why are there positive and non-positive valve types? Why would you not want a positive seal?
