The other day I noticed my return jets have really low pressure(almost none) my and Zodiac suction side pool cleaner is not working, I checked the pump and it had lost prime. I attempted to fill the basket with water and noticed some air bubbles escaping the skimmer, checked the water level, O-rings, surface plumming for leaks, pulled apart the pump and cleaned the impeller and all seemed to be in order. I followed all the troubleshooting steps and figured I'll check the lines with a rubber bladder to check for a blockage. Putting the bladder in the skimmer to return water to the pump basket, I do get water but the volume is not enough to fill the 1 1/2 inch pipe and I'm assuming this is due to the garden hose not having enough throughput to fill the pipe with water(?). Going from pump basket to the skimmer, I can see water flowing nicely but I also see bubbles - like a lot of bubbles - the bubbles eventually die down and I get no more bubbles after about 7~8 minutes of water running through the line(is this normal?), but shutting off water for about 20 second and redoing the whole process again, I get massive amount of bubbles again, is this normal? Can a water leak underground introduce air to the pump?
One other theory I have is that my DE pump has not been cleaned for about 6 months, if the pump is clogged can it cause low pressure in my jets or cause the pump not to prime?
Sorry for the long winded post. I appreciate all the help.
