- Mar 19, 2021
- 186
- Vinyl
- Pentair Intellichlor IC-60
Hi folks - hope all are well. Just reopening season here and wondering if I'm dealing with section-side leak.
I always run my VS pump low and slow, 24/7 (25GPM, kicking up to the 40s when there's a heat call). At that low speed, I always had plenty of air bubbles in the pump basket/under lid. However, last season at that same low speed, my cartridge filter registered about 10PSI.
Now my filter pressure is only 3-4PSI when the pump runs at 25GPM, and goes as high as 15-20PSI when the pump rumps up to 65PSI for a high-speed quick skim. This 3-4PSI at normal, low speed is the reason why I ask if I do have a leak... everything otherwise works well, good circulation, skimming, no outcome to complain of.. I just don't get what could have caused filter pressure to drop that much.
I of course cleaned skimmer and pump baskets, tightened and lubed suction side unions at the pump + pump lid to ensure the low pressure wasn't due to that.
I also used both a drain king (drain bladder) and a cyclone blower to dislodge any potential blockage in the suction pipe, and...:
1) inserting the bladder into the pump suction pipe, literally nothing comes out of the skimmer end - which makes me think bladder is pushing water out from underground leak? (I thought this would result in water being forced out visibly from skimmer just like when blowing lines)
2) inserting blower into the pump suction pipe, water bubbles out of skimmer (though perhaps not as strongly as should)
3) inserting blower into the skimmer suction pipe, there seems to be way more resistance and I can't keep vac hose into skimmer hole for more t
han a couple seconds... which makes me think maybe there is an obstruction close to skimmer end
So, I am not sure if I have a leak, an obstruction, or nothing at all (and maybe for my pool it is indeed normal to only have 3PSI with a clean filter and low-speed circulation at 25GPM).
What do you think is going on re leak vs no leak? And if pool works well, are there any problems with very low filter pressure anyway?
Thx!!!
Thx!!!
