I just ran a new set of numbers today at 2pm. Note there was a typo in my original post about the BTU output and I omitted a zero. [emoji51]
Today's result:
Starting pool temperature was measured at the skimmer (where the water feeds to the pump).
Flow rate measured by directing all solar output into a 5 gallon bucket and timing how long it took to fill to the brim.
Final temperature gain measured with same pool thermometer.
Initial temp: 80 degrees F
Final temp: 85 degrees F
Flow rate: 5 gallons in 2:03. We'll call it 2 mins for easy math~2.5 gallons/minute.
BTU output = (flow rate gpm) x (8.2lb/gallon) x delta T x (1 BTU/lb-F)
=(2.5gpm) x (8.2lb/gallon) x (5 degrees F) x 1 BTU/lb-F
=102.5 BTU/minute
= 6150 BTU/Hour
We have direct sun on this panel from 11am - 5pm. After 5pm the temp output drops way off.
I will run the actual numbers this afternoon to see when the output drops off.
Today's result:
=102.5 BTU/minute
= 6150 BTU/Hour
