My hot tub cover finally showed up yesterday! I still need to take and post pics of that, but let me back up a bit. When I realized it was going to take much longer than expected I made a temporary cover using foam boards with 3.5” metal stud track taped around the outside and plastic taped underneath. I used 1.5 inch and 2 inch thick foam boards to fit within the track and secured everything with gorilla tape. I’ll admit, I got a little carried away with this temporary solution and it ended up costing way more than I care to admit. It’s all good though because I’ve actually been able to use the hot tub for the last 4 weeks.
My thoughts so far:
I use this thing WAY more than anticipated. I hop in most mornings, when I get off work, and sometimes later in the evening. The novelty might soon wear off but at the moment I’m really enjoying it.
With the temporary cover and not-yet fully completed insulation I’m using about 16-18 kilowatts per day. At 0.41 cents per KW-hour you can do the math. Frankly, a couple hundred per month for something I use every day is not problem in my book, especially considering the overall cost of living in southern california. Insulating the bottom of the tub during construction however would have been a worthwhile endeavor.
The MegaChlor is indeed a beast. I mostly use settings 1 or 2 out of 10 and don’t manually dose after use. I figure with 800 gallons there is enough volume to buffer the swings in FC but I’m still figuring out the best approach. I usually see the FC levels rise or fall less than 1 ppm day to day and turn it up or down as needed. Had I known there was the SmarterSpa option I might have paid a little more for the “automation”.
I like 102 and I don’t necessarily care for jets or bubbles. The light is worth having but never used.
I need to build steps for the front.
I developed quite a bit of scale on the plaster in the first few weeks when the pH very quickly wanted to be 8+ and I couldn’t keep up. Also not brushing plaster dust for the first few days surely didn’t help. It might be that I’m finding ways to accept faults but I don’t think it looks that bad. Maybe even a little rustic charm to it lol.
We had some friends over a few weekends ago for the first hurrah and it was a huge success. It was an awesome feeling getting to hang out and enjoy all the work and planning that went into it. I included a photo but threw a filter on for privacy.
