I'm new to the forum since I recently purchased my first pool along with a house we just moved into - extremely thankful for all the knowledge I've absorbed so far. Currently the pool has what I believe is an EasyTouch 8 automation system, with an IntelliFlow pump, Boost-Right pump for pool sweep, 120V IntelliBrite LED lighting, and an IntelliChlor SWCG. The system works great but I'd like to add remote access capabilities, and I believe that means I either add ScreenLogic, or upgrade to Intellicenter. Rather than spend the money on a legacy system like ScreenLogic, I'd rather put that money towards upgrading to Intellicenter.
If I were to purchase the correct kit online, is this something that can be done DIY? I'm perfectly comfortable working with 120V wiring, and all of the related safety procedures. I'm just not sure how good the directions are for the upgrade, and whether there would be any warranty implications. I believe the Intellicenter also uses a new style valve actuators? Would that just be an easy retrofit from my existing Pentair valve actuators, or would I just continue to use the existing actuators?
Thanks!
Thanks!
