I bought my house last Fall and it came with an older, in ground pool. I used to be in charge of chemicals at a large public pool, so those aren't a problem. However, I have little experience with home pools.
My brother in law went a bit overboard with jumping on our diving board over the holiday weekend. The bolts that attach the diving board to the base pulled out of the base. I assume the bolts/nuts rusted from being so old. They were all stripped when I pulled them out. Google Earth shows the pool being installed sometime before 1994. I have no idea how old the diving board and/or base are. My plan was to take the base off the concrete, grind the nuts off the inside of the base, and weld new nuts onto the base. Simple enough job.
Well... it was supposed to be simple. When I was detaching the base from the concrete, one of the rods that is anchored into the ground snapped off. Awesome!
The other rods are a pretty rusted too.
So, my new plan is to detach the base from the rods, cut/grind them off at the concrete level, and then move the diving board 2" to the side. I'll have to drill holes into the concrete, anchor the threaded rod into the holes with an epoxy, and then attach the repaired base to the new rods/anchors.
Does that sound like a good plan?
Can I just move the location about 2" to the side without any trouble?
What epoxy should I use to anchor the rods? The "SR Smith Epoxy Kits" are crazy expensive. Can I use an epoxy like Quikrete high strength anchoring epoxy (Product # 8620-31) and a high quality stainless steel rod? https://images.thdstatic.com/catalog/pdfImages/32/3254ef0f-d6d8-4a96-93b3-17d80b55dce6.pdf
