Anyone look at or have experience with this salt and algae control system. Looks very interesting.
The Complete Pool System | Dive Smart Sanitizerâ„¢
Looks like an SWG with copper ionizer built in. Lol, even Intex wised up and ripped out the copper ionizer from their SWG models, you would think most would. The most interesting thing to me is that they create a flashy looking SWG (looks like my NOCO battery charger) and market it as some SWG of the Future but put in a feature that even the cheapest SWG manufacturers have forgone for other marketing ideas.
I find the "salt and algae control system" moniker to be quite confusing. SWG's produce chlorine, chlorine controls algae, so every SWG is an algae control system.
EDIT: Oh wait, I missed that it runs off of a turbine instead of being plugged in to a wall. Well, assuming this thing works at all, that essentially means if you want any meaningful chlorine production you need to run your pump full bore. If you have a single speed pump that might be ok, but if you have a 2-speed or VSP then you are going to spend much more running the pump faster than should be necessary than you would for the electricity to run a proper SWG. Given that this thing won't be installed in some remote location, there has to be electricity coming to the equipment pad, there is no reason to have such a feature except for the flash factor.
So what are your thoughts about the system now?
Neat concept. As internal turbine, which is powered by the water flow, creates the necessary power to run the cell. At 40 GPM water flow they claim a 0.8 lbs of CL production. They claim a max flow of 60 GPM. Probably OK for a smaller pool. No flow, no power; so, flow switch is not needed.
I can see the other guys going this route. Pentair already has the electronics on the cell.
)Formarum has developed a breakthrough solution for harnessing the energy of small-scale fluid infrastructure The company’s patent-pending turbine technology extracts the power from inline flowing water and can redeploy this energy in a variety of ways to create customer value
So I bought this system 3 years ago but now they went bankrupt…Honestly I love it
The fact that I dont have to pay $2k just for automation is great..
It will show lots of info including temp.
I dont like the startup cost :-(
I had .75 HP Intex pump and it was right on border..
I wanted to upgrade my pump anyways so I went with Hayward 1.5
I have AGP
had to reset the unit but can’t get it to work with browser since their app was also pulled from App Store…
anyone knows how to get is connect via browser ?
I see the ip that it’s connected on my network
I did… nothing happensDid you try putting the IP (instead of URL) directly into your browser?
You probably need to connect directly to it the first time to set it up.... as in join the Wifi network it is broadcasting or via Bluetooth. The cameras at my beach house do this when they get reset... once connected I can configure them to join the house wifi network. Unfortunately, their app may be required to configure the device once you're connected.I did… nothing happens
I had to reset the unit so I think it’s failing to connect to my wifi
Strange thing is that I see the unit when I look at the router connected device
Wifi glades on the Dive system so not sure if it’s connected to my wifi correctly or not..
You’re correct but without app is impossible to connect via wifi to it directly!You probably need to connect directly to it the first time to set it up.... as in join the Wifi network it is broadcasting or via Bluetooth. The cameras at my beach house do this when they get reset... once connected I can configure them to join the house wifi network. Unfortunately, their app may be required to configure the device once you're connected.
