I have a 10k pebble tec pool with a 1.5 single speed pump and sand filter. I have the Taylor kit. I don’t always run all the tests.
This has been happening for a while when I brush the pool I will see brown stuff that clouds the pool (usually after it’s been very windy) and then the pool will be fine when the weather is calm. I’ve raised the FC to slam levels a few times and have kept it fairly high. So I’m inclined to believe that it is dirt not algae. Anyway I’m open to what you think.
This is what happened this past week:
Saturday: I brush the pool walls and there’s minimal dirt. FC 6; CC 0; PH 7.5; CYA 60 CH 450 TA 60
I decide to start slamming and add 10% bleach
Sunday (lots of wind overnight and there’s a lot of little debris in the skimmer basket- when I reach into clean it my arm is covered in small particles). Initially FC 19 Ph 8
I add more bleach and MA
FC 24 ph 7.4
Monday: brush and there’s hardly anything on the stairs and walls. FC 24 ph 7.4
Tues and Wed morning same as Monday minimum dirt and debris seen when brushing FC 24 ph 7.4 Weather calm
Wednesday day and night very windy. I skim the pool a few times throughout the day and before bed.
Thu (today) the pool had a lot of debris and leaves in the morning (filter set to start at 9am). I skimmed and brushed the walls. There was a lot of brown stuff that made the water cloudy when I brush the walls. It did puff up and form a cloud towards the bottom of the pool and kind of hang there for a bit. FC 21.5 ph 7.4. Out of precaution I added bleach to raise FC to 24.
I noticed the vacuum didn’t get all the brown stuff and it’s obvious where the vacuum missed. The water is clear (not murky).
So is this algae or dirt?
FC 24 ph 7.4
