I use a battery operated vac for my pool but I still have to vacuum everyday why is this happening I so.etimes vac twice a day I don't use a vac hooked to the pump have an I tex with two pump return and one jet skimmer is on the pump
Welcome to TFP! We need more info to help answer your questions. For example:
- How are you testing your water?
- Can you post a full set of test results?
- What vacuum make/model are you using?
Your signature doens't have anything about yoru pool or equipmetn listed. That info is very important for us to help. See my signature as an example.
