New Tristar SP32950VSP pump installed. Just want to be sure I’m understanding Dip Switch settings correctly for communication with my ProLogic PL-PS-16. The Prologic will be controlling the 950. What should those setting be?
Have you seen JamesW's post? Better to have the options and not need them than need them and not have them. Hayward has pretty much covered all the contingencies that may arise in a complicated pool installation.Strange that the pump comes with dip switches having no function.
Would like to hear from Tristar owners regarding their dip switch settings and configs.I don't think that it matters for this pump.
They need to have the exact same model as you have.Would like to hear from Tristar owners regarding their dip switch settings and configs.
Yes, works. Model is SP 32950VSP installed by Florida Licensed Professional Pool installer who said the setting should be 1 on and 2 - 5 off.The post where you got the picture is 3 years old and the pump is a different model and the automation is also a different model.
Your pump uses the interface to set the address.
Did you install the pump or did you have it professionally installed?
Is it working correctly?
Can you show a picture of your wiring compartment?
Shellie posted this 04 July 2019 - Last edited 06 July 2019
Communication Issue Between TriStar VS900 Pump and OmniLogic
We have recently upgraded from an AquaRite pool control system to the more robust OmniLogic. For the most part, things have gone smoothly. The only real problem we are having is that the Omnilogic doesn’t seem to want to communicate with the pump. The pump model is a Hayward TriStar...www.inyopools.com
