I have a 2017 Dimension One Aurora spa and am having trouble getting it to start after changing the water. I've done everything I know to do from previous experience with this procedure. As far as I can tell there is no air lock as both the jet pumps come on and circulate the water as usual. But the circulation pump does not move any water even though I can hear it running. And without the circulation pump the heater won't come on of course. I've checked the fuses for continuity and all check good. I've put a hose into the outlet in the footwell where the circ pump usually sends out a stream of bubbles and some air did burp out of the system but now I don't believe that there is any air left in the system. I've removed both filters and unscrewed the caps next to the filters and run water into those openings which used to be enough to get things going - not this time. Anyone have a similar experience? Thanks for any help anyone can offer.
