Re: Digging up pipes & starting over: all new PVC, pump, filter, skimmer, heater, etc
Pushed the install date back to June 13th due to needing a new skimmer (old one had LOTS of cracks, one of which was leaking!) which is on back order, and of course it will take a while to get a new liner made up to fit our pool.
Working out the details of adding a second return, likely using what was once the deep end low wall vacuum line as a return and putting in a new low wall vacuum line somewhere closer to the middle of the pool. That'll be nice, as we could never vacuum a corner of the shallow end due the old vac line being so far away. Shallow end eyeball will push water up towards the middle and the deep end eyeball will point down toward the "bowl" to help circulation down there.
Electrician is coming tomorrow to run wire and set the subpanel for the pool equipment. Going to figure out what works best for the bond wire through the concrete. Might even try to run the electrical up through in some rigid pipe, to keep liquid tight wire whips from getting in the way of the working area. Hoping he want charge extra to wire up the Intermatic surge protector I ordered.
I'm still digging. Lots of rain this past week has prevented digging, and what digging was possible was pretty messy until it dried up a bit. Thankfully we get extra time to keep digging.
