My old filter and MPV gave up the ghost, so I replumbed the pool, removing the booster pump that never got used, and upgraded to a glass based 28in filter (rather than the old 31in sand filter that came with the house) with a new 1.5hp astral ctx400 pump
The pool box is mostly below the water level, with the chlorinator setup slightly above water level. The pump is about 1-1.5ft below water level.
My kit is as follows
- Ancient Poolrite S-1800 pool skimmer (i think). I cant find any specs for its port sizes, but they might be a touch smaller than 40mm
- 1.5hp 50mm astral ctx 400
- Zodiac chlorinator
- 28in davey crystal clear glass filter
- 40mm jandy cut offs to the outlets
- 50mm jandy cut off inlet that is supplied by 40mm pipe from the pool-
- 50mm pipe in the box until it gets to the chlorinator
At the moment I have been trying to work out why it wont prime properly. The pump will gravity fill if the lid is removed, and generally starts out with more water but often ends up with somewhere between 25-80% of the basket full, never fully getting to the top and sending a stream of bubbles through the chlorinator and outlets.
What I've done so far;
- Added several inches of pool water & removed the weir
- Ive added a bleed valve to the filter to try and ensure air trapped there hasn't been an issue which hasn't seemed to help much.
- Checked all the unions multiple times as well as connections to the pump
- Removed and replaced pump drain valves (slightly suspect about one possibly having been cross threaded from the factory, but seems to seal on the o-ring with enough pressure)
- Checked pump basket orings etc multiple times
- Wrapped all suction side fittings with plastic to check for suction/air
- Sprayed all suction side fittings with water to check for suction/air
- Tried every setting on the MPV to get prime. Filter seems better than backwash or rinse for whatever reason
- Disconnected the chlorinator, and primed from the highest point in system while valves were off, reconnected then ran from there
Mostly this hasnt improved things much.
I even went as far as running an 800gph bilge pump to push water directly into the skimmer suction port. This seemed to help and got us about as close to primed as I have seen so far, while it was running.
The pool shop guys only suggestion was to keep running it trying to prime it, or to add a non-return valve between the supply cutoff and the pump.
Any suggestions or critique on the plumbing appreciated.
