Hoping the brain trust here can help.
16K Gal pool, 1.5HP Pentair whisperflo pump, 1HP pump to solar heat, Paramount in floor cleaning system. Hayward SWG.
Here is the issue. Pool originally came with a chlorine feeder, i had the Hayward SWG installed. Shortly after i noticed that the heads in the infloor cleaning system are no longer popping up, also when i turn my valve to sunset fountain water flow does not increase dramatically. Prior to i could create a continually running fountain almost to my 2nd story.
Did installing the SWG grealy reduce water flow?
Do i need a larger pump?
Pump motor is fairly new, 1-3 years old
I have checked/replaced filter (cartridge type)
I have changed impeller.
Any ideas?
Attached is a pic of setup.
Any ideas?
