- Jul 22, 2022
- 77
- Plaster
- Hayward Aqua Rite (T-15)
This is a slight continuation of another thread A little over a year since the last drain and fill, should I drain again? Calcium Hardness through the roof I was looking into getting my autofill moved to help reduce increasing CH due to the fact our source water is about 290 ppm.
I happened to notice a spot on my pool floor that looked like there were several pieces of plaster chunks. Turns out a small area seems to have either delaminated or something else. Only one spot that is obvious, hasn't seemed to get any bigger.
Tonight's numbers:
FC 3.4
CC 0.0
pH 8.0
TA 80
CYA 50
CH 870
Salt 3400
Current CSI value 0.62 (added 38 oz to bring pH down to 7.0)
The pool was finished in December of 2022. The plaster company has already made claims at least once that I didn't "brush enough" and the PB had to fire back with they haven't had a customer who brushed as well as I did. I was going out multiple times a day for over a month. The plaster company denied damaging my kool deck paint that was applied and I had to show video of them dropping their hose right on it and damaging it before they actually did something about it, so I already have a history of them trying to make themselves not liable.
All that said, they are coming out for an "inspection" in a few weeks to determine what is going on and whether they are covering it. $100 on them blaming pool chemistry. Hoping I don't have to get a lawyer but I will if I need to, assuming the general consensus is that I couldn't have caused this by keeping improper balancing.
Pictures attached. Honestly looks worse in the pictures than it does in person and the black marks were me poking it with my brush pole because I thought the water was playing tricks on my so I wanted to "feel" the drop that I could see and sure enough, it was there. It's much more visible at night when light hits it as all plaster imperfections show up quite easily like that. Visibly looks about 6" x 2" or so. All the pieces I was able to retrieve (there must be more but I can only assume they got sucked into the main drain or something because I have ran a vacuum to collect more and I've only seen a few more smaller pieces. All of them seem to be roughly the thickness of a quarter. To me, it seems like delamination and the fact it isn't happening everywhere would indicate this isn't a maintenance problem but was a problem at the troweling phase.
Tonight's numbers:
FC 3.4
CC 0.0
pH 8.0
TA 80
CYA 50
CH 870
Salt 3400
