Hey all, I had a lot of ugly iron stains and performed an ascorbic acid treatment in September 2020 in accordance with a couple TFP threads. Took a while, but it worked great! I used Jack's Pink Stuff as my sequestering agent. I was reluctant to spend $100 on a Sequestrant test kit, so I didn't, nor did I continue using the Pink Stuff after the AA treatment. As of July 2021 my pool still looks great, no stains or issues. I do however, have a bottle and a half of Pink Stuff left over.
My question is- do I need to bother using it if I'm not seeing new stains? (& risk potential phosphate buildup with regular use)
I realize that the metals that caused the stains didn't magically disappear, but we have had tons of rain this year, to the point that my CYA fell by 1/2 and my CH by 1/3 since about February. Is it possible that the metals have been similarly diluted? Is there a magic number of sorts to determine when iron content is high enough to warrant using a Sequestrant as a preventative?
This is an old pool (1961). Plaster is decent, not great. You can clearly see many rebar spots on the bottom of the pool. (Could this be how iron is getting into the water?) Naturally, I'd rather buy the $100 kit and use a sequestrant regularly than fork out big bucks for a replaster. Even better- to do none fo the above if it's not really necessary. What would you recommend?
Thanks!
Caracat
Thanks!
Caracat
