Design suggestions ideas
Blueice89
Active member
Dec 13, 2019
43
Gilbert Arizona
Pool equipment and some steel in place . Construction going well so far . We had some delays cause we got a 400k but heater and now burying a 500gallon propane tank in our front yard !
Reactions: JRB100
kimkats
43,292
Tallahassee, FL
Front yard??? You will have some major yard work to do when this is all done!
What will you be putting down around the equipment? I have ideas if you have not thought about it yet.
Kim:kim:
kimkats
43,292
Tallahassee, FL
The stucco wall would match the house but I worry about how much room there is to move around the equipment with how close the wall will need to be to it due to how close that spa will be. A pretty lattice wall will be thinner and provide good air flow around the equipment. Inside the equipment area I would put down a GOOD weed block and a solid "floor" of stepping stones then large rocks like river rock all around the equipment its self. It will be a pain getting the weed block in there but it will be well worth the effort to keep the weeds and such out. I would use "lawn staples" to help hold it down in there as well.
kimkats
43,292
Tallahassee, FL
That looks awesome! I really like the lay out! Glad to hear you are already bonding with your pool. It is time for YOUR set of links!
The first set is how to get a great plaster job and the second set is how to care for it after the PB is done.
Plaster links:
Ten Guidelines for Quality Pool Plaster Best one of all
All Plaster Finishes Should Last 20 Years
Not All Color Pigments are Good for Pools How to pick a good color for plaster.
A Plastering 'Watch List' | Professional Watershaping | Watershapes
Trouble Free Pool
Trouble Free Pool
Pool care links:
Print these out:
Bookmark these:
Trouble Free Pool
Now is also a good time to ask what test kit your PB will be providing so we can fill in any holes.
Kim:kim:
Blueice89
Active member
Dec 13, 2019
43
Gilbert Arizona
We have had a couple week delays cause we needed permits to bury our propane tank . It’s massive 500 gallon and large and in charge . It will be buried alive . Our neighborhood has no gas hook ups propane is only option to heat spa and pool.
kimkats
43,292
Tallahassee, FL
OUCH! I bet that hurt the wallet some but man will it be worth it when you are sitting in the spa with an adult drink in hand after a long days work!!
Kim:kim:
