to deactivate a timer set the start and stop times the same on each timer
From the manual:
Page 23 of 36
TriStar VS 900 Pump
IS32900VSP Rev-B
Note:
When start/stop times are set to be the same, the timer is deactivated. Each timer can be set to run on
specific days of the week. Options are to run 7 days per week, 5 days per week (Monday thru Friday), or on a single
day (Monday thru Sunday). Each timer is set up in this same manner. When
the pump is powered and the timers are set up, the Timers Active LED will illuminate. If the timers
are set up such that their run times overlap, the timers will run in priority from Timer 1 to Timer 8. In other words, if
Timer 1 is set to run from 8:00 am to 12:00 pm, and Timer 2 is set to run from 10:00 am to 2:00
pm, the pump will run Timer 1 from 8:00 am to 12:00 pm, and will then switch to
run Timer 2 until 2:00 pm. Default setting for Timer 1 is to start at 12:00 am, and end at 11:45 pm. When Remote
Control Mode is set to Relay Control,the speed for Timer 1 may be set to 0
rpm to allow the pump to be stopped without having to remove power.
