Is it okay to drain the pool down to below skimmer level when I change the sand in my filter?
When I go to clean the pump's basket water is constantly coming out. The intake has a 3 way valve, but no "all off" position, just "skimmers", "both", and "drain". Since the pump is lower than the skimmers, it seens the only way to cut off flow to the sand filter would be to drain the pool from "drain" down to below skimmer level and then switch it to "skimmer". Would that be okay for a liner pool?
