- Apr 24, 2021
- 43
- Vinyl
- CircuPool RJ-60 Plus
Hello! My pool is staying cloudy for weeks, and it is going to be very hot coming up so i want to get it all in order asap.
Backstory: The pool cover got lost in the late fall and we thought: how bad can it be, we always end up dumping the leaves off the cover anyways?.... But it got so full of leaves and gunk. It was a swamp with water striders and paddle bugs and even little red worms at the bottom. We will never do that again.
I first adjusted the ph and got it steady and now, it is all cleaned out of any debris for 2+ weeks, and has been being extra high chlorine slammed and 24/7 filter running (with small bonus DE and frequent backwash) and an "everything-even-the-waterline" scrubbing robot running 4 x a day for 2+ weeks, the water is all nice and blue, and we haven't had more than 1 cc for 2+ weeks, and it has been progressing from opaque blue to clear but verrrry gradually each day, with the overnight chlorine test finally going pretty good last night (but i apparently didn't log it in the app right this early AM : We lost 1 fc and had barely anything .5 cc).
I would now like to deep clean the sand filter (never been done x 3 yrs + swamp) to give us the best chance of getting a crystal clear pool next week. We do have heavy use for the entire season plus the recent swamp fiasco, so I'm sure it could use it.
Concern 1: My pool is obviously already full of water. If i plug the skimmer and pump return the best i can, and then undo the hose screw rings at the pump connections (two red dots), and then bungie the ends of the hoses up high to a poolbrush pole handle higher up than the water level, will that disconnect the pump from the system and make the water stay in the pool?
Concern 2: if i take out gooky sand do i need to replace it with any more? I did not see that in the deep clean video.
Concern 3: Is there any chance the DE is making it cloudy and i should stop that after the deep clean? It's pool grade DE.
Ps. We never take our stairs out bc we attached them to the pool deck rail for extra stability, but we could undo them. There's a gap so i can scrub the wall/bottom behind them, but not really the undersides of the steps. Could there maybe be mustard algae or something adding cloudiness?
Thanks!
Thanks!
