Highly confident. I am a chemical engineer by training so I am probably on the extreme side of being exact with my testing and rinsing. I repeated the test three times just now on a new sample and got 50 each time. I am using the TF100 test kit with the black dot test holding the tube at my waist. At around mark 55 viewing the dot gets iffy but at 50 it is totally obscured and when I go beyond the 50 line there is no change to the visibility in the tube.
I do not measure the bleach so exact but I am erring on the side of bumping FC a bit over shock level but not by much, maybe a few ppm at most.
As for Jack's, I switched to it earlier this week after I cleaned the filter so I now have 96 ounces in the system. Should I add more? At $25 a pop and $40 for AA would I be better off getting my water balanced and then later doing another AA treatment (adding Polyquat this time to keep away algae) to get rid of the staining?
Bleach is affordable and gets us swimming again. I just don't want to dump another $100 into the pool for stains while I am continue to dump in so much chlorine, which could be what is making the plastic yellow. No other stains have reappeared on the plaster, just on the plastic components.
