CONFESSION TIME...
I let my pool turn to a pond this winter. I made this decision after letting it get so nasty that the pressure rose and cracked my manifold, allowing all my DE to enter the pool. I’m familiar with this because I did the same thing last winter.
MY JOURNEY BACK...
I replaced the manifold and my grids are like new. I’ve cleaned out all the debri and slammed the pool until the water is clear. I’ve rinsed and reapplied the DE several times. The water has cleared up, but I’ve still got a lot of DE in my pool. Last night I brushed the pool thoroughly and let the pool run with fresh DE on the grids. My pressure was sitting at normal clean, 18. After 2 hours the pressure jumped to 40 and I had to shut it off. This is the 2nd time this has happened. I turned the pool off and left it overnight. Today I turned the pool on, pressure was at 18, but I had DE blowing into the pool. I shut it down, opened the filter, and everything looks to be in order. Manifold is not cracked, grids have no visible holes, and the DE was still white and evenly coated on the grids. The O-ring and vent are also in fine shape.
HOW IS THE DE GETTING BACK TO THE POOL?
Why is my pressure rising so quickly with clean filters?
The pool has lots of particles to filter, but it shouldn’t be spiking that quickly. Could I have too much DE?
All suggestions are appreciated. Thanks for tuning in.
MY JOURNEY BACK...
