I am having an issue with my DE Filter. I cannot keep water going through the filter when it is set to normal filter. When I first start my pump, everything appears to be fine; pump primes, water flow is good, and the pressure is about 18. Within 10 minutes, the pressure has gone up to 30 and the pump ends up losing prime and will not pump any water. I have taken the cleaning grid out and hose them down and they appear to be in good condition. I have even done an acid bath on the grids. If I run the system on backwash it works fine; although I have not run it for 10 minutes on backwash. Also, if I just run the system on recirculate, bypassing the filter, it also runs fine.
Please help, I am at a loss.
