I opened the pool on Tuesday. The DE filter was packed with DE so I hosed all that down. The company I used to close the pool never cleaned it. Started up with four scoops of DE. Starting pressure is 20, max is 35. I hit 35 pretty quick and assumed that makes sense since the water was so dirty. But I’ve had to backwash roughly every 1-2 hours since then.
At first I added 2 scoops of DE after a backwash but with the pressure issue I thought maybe there’s too much in there. So I reduced it to 1 scoop and eventually half a scoop after each backwash. Today I decided not to top off the DE at all and it still hits max pressure after a couple hours. So I backwash and repeat without adding DE.
Is this a normal thing? It requires a whole lot of babysitting and more than the previous owners would ever give. Plus, the water is still pretty cloudy so that’s depressing.
Inground bromine pool, 50K gallons.
